mchan68 Posted September 29, 2009 Share Posted September 29, 2009 Can anyone come up with the correct part number for this pulley illustrated below? Pulley diameter is about 2-3/4" with a spacer behind it approximately 1" long. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted September 29, 2009 Share Posted September 29, 2009 Mike, is this a tow truck or anything with a belt driven PTO? If it is chances are that the body builder installed it. If not can you expand on the vehicle information for me? Quote Link to comment Share on other sites More sharing options...
mchan68 Posted September 29, 2009 Author Share Posted September 29, 2009 Mike, is this a tow truck or anything with a belt driven PTO? If it is chances are that the body builder installed it. If not can you expand on the vehicle information for me?I'll try to dig up the VIN for you. All I know so far, is that this is a dual alternator equipped truck, WITHOUT the second alternator installed. Customer states that there IS aftermarket equipment installed independently of the factory front end accessory drive. Last night the parts manager and I tried looking through HvBOM and every possibility listed in Microcrap without success. Quote Link to comment Share on other sites More sharing options...
BrunoWilimek Posted September 29, 2009 Share Posted September 29, 2009 If all else fails, Mike, and the pulley itself is not damaged, you may be able to press out the bearing, match up the number on it and just replace the bearing. I have done this on several pulleys that were not available locally, yet the bearing was. Of course, if pulley is damaged, this will not work. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted September 29, 2009 Author Share Posted September 29, 2009 Not that it matters, but the VIN is 1FTWW32P14EE06754. Quote Link to comment Share on other sites More sharing options...
Aaron Posted September 30, 2009 Share Posted September 30, 2009 With that spacer on it it kinda looks like an aftermarket gizmo. Is it in the main (factory) drive belt routing? Quote Link to comment Share on other sites More sharing options...
mchan68 Posted September 30, 2009 Author Share Posted September 30, 2009 With that spacer on it it kinda looks like an aftermarket gizmo. Is it in the main (factory) drive belt routing?That's what I was thinking too. According to the customer, it IS part of the factory drive belt routing. Quote Link to comment Share on other sites More sharing options...
Aaron Posted September 30, 2009 Share Posted September 30, 2009 You don't have the truck on site? See if customer can bring vehicle or picture of the accessory drive. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted September 30, 2009 Share Posted September 30, 2009 Quote: According to the customer, it IS part of the factory drive belt routing The only thing I want to know from the customer, is when it happens, what happens, how long has it been happening, ect. When it comes to whats actually on the vehicle, customers dont know a fuckin thing about it, unless they built the thing for cryin out loud. This customer is pullin your chain, Mike. There's no way that this customer can say without a shadow of a doubt that that pulley came on the truck from the factory. You've worked on a ton of these, and I'm sure as I to, have never seen this pulley from the factory. Seen alot of them that look like that, that have aftermarket PTO setups though. I would consider finding out what the aftermarket setup is and seeing if they have a phone number, if all else fails with the bearing I.D. Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted September 30, 2009 Share Posted September 30, 2009 Mike, Do you have a body builder that your sales dept uses? Usually they can identify the pulleys. If not send me the pulley and I'll find the correct one for you. Quote Link to comment Share on other sites More sharing options...
partsmanBB Posted September 30, 2009 Share Posted September 30, 2009 I have run into this several times here with one of our fleet accounts (we are right up the street from ESPN world headquarters, and they have a million buses and trucks). It's never easy, but the Dayco and Gates websites have good listings with clear pictures, maybe you can match something up. You sometimes have to make a bit of a guess, but it may work out--hope this helps. Quote Link to comment Share on other sites More sharing options...
