robp823 Posted September 29, 2009 Share Posted September 29, 2009 Got an 07 f-450 that bucks and jerks.The only codes in it were a p0528,p0148, and p1705.My p0148 keeps coming back.Anyone ever get this DTC before???Fuel Delivery error??This is the first time ive seen it.Watching pids everything looks normal except when it happens ficm sync goes to no.Fuel filters are good and fuel pressure is in spec with the valve on the tester open. Quote Link to comment Share on other sites More sharing options...
GregKneupper Posted September 30, 2009 Share Posted September 30, 2009 I had one a long time ago that ended being a pcm. Really kicked my ass. The one I had all you had to do was tap on the pcm lightly with a hammer and the engine would shudder when you tapped it. Quote Link to comment Share on other sites More sharing options...
robp823 Posted September 30, 2009 Author Share Posted September 30, 2009 hmmm well i got tied up with an stc fitting on an lcf today but i will give that a shot tommarow. Quote Link to comment Share on other sites More sharing options...
GregH Posted October 1, 2009 Share Posted October 1, 2009 Does it buck and jerk at a certain RPM? Will it do it in neutral in the stall? How about unplugging the fan and the alternator? I had one that kicked me too - had to scope the lines between the FICM and the PCM and finally found the PCM making the square wave CMPO too long at times. The FICM didn't know what to do with that signal so FICMSYNC turned to No and the engine started to jump around in the engine compartment... There is a thread on here about it.... Quote Link to comment Share on other sites More sharing options...
robp823 Posted October 1, 2009 Author Share Posted October 1, 2009 cool ill look for it or if you have a link??? Quote Link to comment Share on other sites More sharing options...
robp823 Posted October 3, 2009 Author Share Posted October 3, 2009 Ok well after resistance checking and load testing all the powers and grounds to the FICM and also the communication circuit and finding nothing wrong.I had an excursion in the bay next to me so for the hell of it i swapped FICM's and problem solved. Quote Link to comment Share on other sites More sharing options...
Aaron Posted October 3, 2009 Share Posted October 3, 2009 I have a known good test FICM Quote Link to comment Share on other sites More sharing options...
joshbuys Posted October 3, 2009 Share Posted October 3, 2009 We have a known good test FICM here also....it's brand new, so if it fixes the problem, it get's left in the truck and gets replaced by the new one from parts....only have to program it once that way! Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted October 3, 2009 Share Posted October 3, 2009 I recommend in all of my classes that the techs keep a known good IDM and FICM on the shelf for test purposes. If you can't find one easily, www.car-part.com has used ones for $100 or less. Good Luck! Quote Link to comment Share on other sites More sharing options...
robp823 Posted October 3, 2009 Author Share Posted October 3, 2009 cool thanks it sounds like a good plan to have spare ones on hand. Quote Link to comment Share on other sites More sharing options...
Aaron Posted October 4, 2009 Share Posted October 4, 2009 I recommend in all of my classes that the techs keep a known good IDM and FICM on the shelf for test purposes. If you can't find one easily, www.car-part.com has used ones for $100 or less. Good Luck! Would you believe my parts department quoted a customer $780 for a USED 7.3 IDM? Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted October 5, 2009 Share Posted October 5, 2009 Would you believe my parts department quoted a customer $780 for a USED 7.3 IDM? Is that the same one you called me on? Quote Link to comment Share on other sites More sharing options...
Aaron Posted October 7, 2009 Share Posted October 7, 2009 Yeah. Customer found his own from some place in the states - that was that "DG systems" one or whatever the fuck it was I called you about. Claims he paid $251USD for it. All I know is it's on the truck. My warranty's over. Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted October 7, 2009 Share Posted October 7, 2009 He gets what he pays for, just like the customers that go to the quicky oil change places that pay the lube "TECHS" cheap. You pay $8.00 hr to these guys and you get $8.00 worth of experience. Watch he'll be back and pissed at you when it takes a shit. Please keep us posted when he does.... Quote Link to comment Share on other sites More sharing options...
Aaron Posted October 8, 2009 Share Posted October 8, 2009 I've still got the "Installation guidelines" sheet from his bargain IDM on my toolbox, for when he needs to return it. Quote Link to comment Share on other sites More sharing options...
