BLittle500 Posted October 19, 2009 Share Posted October 19, 2009 Hey guys, I'm pretty un-familiar with these engines and being the only diesel tech in the shop I'm just looking for a place to start. Truck has a pretty bad coolant leak, external. I couldnt pin point where the leak is, so I put dye in it. there is dye all over the front cover, in the engine valley, down the back of the engine (more on the driver side) and actually running off the left exhaust manifold. To me it's leaking somewhere in the valley, but I havnt done more than a cooling fan to a 6.4 yet, what all is up top to leak coolant? From what I can tell it's none of the coolant hoses on top of the engine. Thanks again guys, Brandon Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted October 19, 2009 Share Posted October 19, 2009 You may refer to this thread... http://www.forddoctorsdts.com/forums/ubbthreads.php?ubb=showflat&Number=21782#Post21782 Quote Link to comment Share on other sites More sharing options...
BLittle500 Posted October 19, 2009 Author Share Posted October 19, 2009 I had already read through that one, and checked out the hoses, they all checked out good. Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted October 19, 2009 Share Posted October 19, 2009 How about this one.... http://www.forddoctorsdts.com/forums/ubbthreads.php?ubb=showflat&Number=16101#Post16101 Quote Link to comment Share on other sites More sharing options...
joshbuys Posted October 20, 2009 Share Posted October 20, 2009 Inspect the plastic tube that goes to the heater core return - runs along the rh valve cover back to just in front of the glow plug module - those crack - usually not really obvious - check previous work history to see if anyone's had that area apart as that's generally when they get cracked. Quote Link to comment Share on other sites More sharing options...
Aaron Posted October 20, 2009 Share Posted October 20, 2009 I just fixed one, there was fucking coolant EVERYWHERE - it was the seal on the radiator hose to the thermostat housing (housing was all ratty) Quote Link to comment Share on other sites More sharing options...
BLittle500 Posted October 24, 2009 Author Share Posted October 24, 2009 Found it, after looking at the history on this truck, it had a mile long list of previous repairs. After digging and digging I finally found it. Follow me here guys, I'm not to good at describing......At the top of the vertical EGR cooler there is a hose that runs into a tube that runs into a 90* aluminum fitting that goes into the front cover. The damned bolt that holds that fitting in was backed the whole way out and the fitting backed out past the o-ring. Not sure if it was due to the previous repairs or just sh!t luck. Thanks for all of the tips guys, Brandon Quote Link to comment Share on other sites More sharing options...
mchan68 Posted October 24, 2009 Share Posted October 24, 2009 I had one not too long ago, that was leaking externally from the vertical EGR cooler hose. Quote Link to comment Share on other sites More sharing options...
Aaron Posted October 24, 2009 Share Posted October 24, 2009 Found it, after looking at the history on this truck, it had a mile long list of previous repairs. After digging and digging I finally found it. Follow me here guys, I'm not to good at describing......At the top of the vertical EGR cooler there is a hose that runs into a tube that runs into a 90* aluminum fitting that goes into the front cover. The damned bolt that holds that fitting in was backed the whole way out and the fitting backed out past the o-ring. Not sure if it was due to the previous repairs or just sh!t luck. Thanks for all of the tips guys, Brandon My first 6.4 experience was this issue. The bolt was broken off. Had never been apart before. Quote Link to comment Share on other sites More sharing options...
BLittle500 Posted October 24, 2009 Author Share Posted October 24, 2009 My first 6.4 experience was this issue. The bolt was broken off. Had never been apart before. I was kind of leaning towards this just being sh!tty luck, I just couldn't see all the work that had went into this thing before, not being careful and letting something like that loose. Either way, she'll be back on the road Monday. Thanks again guys, Brandon Quote Link to comment Share on other sites More sharing options...
