STROKER_T Posted November 7, 2009 Share Posted November 7, 2009 Got an '08 F550 with 18 miles off the lot,the rear axle is busted....3 of 6 carrier bolts are broke,there is metal throughout the system...did a lukewarm line request They instructed me to replace the third member and flush the axle. Anybody seen this? I'd be more than happy to rebuild it(pays more),service manager had me do the hotline thing and whala...$2000 ring and pinion assembly coming from detroit,should be here next week some time...no way i'm getting ALL the metal out of this axle Quote Link to comment Share on other sites More sharing options...
Aaron Posted November 7, 2009 Share Posted November 7, 2009 More importantly, what kind of noise did that make?! Customer usage or was this on the PDI? Or on the way to the upfitter for a dump box or something? Inquiring minds want to know! Quote Link to comment Share on other sites More sharing options...
STROKER_T Posted November 7, 2009 Author Share Posted November 7, 2009 A whining noise was noticed in the the parking lot,customer was gonna do a road test,pdi didn't catch it...hmmm code c1237,pulled rear speed sensor,speed ring gear tore up...18 miles Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted November 7, 2009 Share Posted November 7, 2009 We had a brand new '07 do the samething. It whined pretty bad. Don't fuck around with trying to overhaul one of these, just replace the third member and get it out of your bay, you will be glad you did trust me. If you do get the third member, a set of old head bolts from a 6.0L are the same thread pitch and diameter as the member bolts to the case. If you have any left over from head jobs you can lop the heads off two of them and use them as guide pins, so you don't fuck up your gasket maker trying to lift that heavy bastard into position. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted November 7, 2009 Share Posted November 7, 2009 If you do get the third member, a set of old head bolts from a 6.0L are the same thread pitch and diameter as the member bolts to the case. If you have any left over from head jobs you can lop the heads off two of them and use them as guide pins, so you don't fuck up your gasket maker trying to lift that heavy bastard into position. Excellent tip! Quote Link to comment Share on other sites More sharing options...
G. Bedford Posted November 8, 2009 Share Posted November 8, 2009 We have had to do a number of wasted 3rd members, too. Overhaul was not really an option due to the damage. Wish the new one would come with a drive flange installed so you wouldn't have to mess with torqueing the nut. We fashioned a flat plate on a section of square tubing that slides over the end of our cherry picker. Just have to bolt the 3rd member by the flange to the plate and let the cherry picker handle the weight. Works well if you have the rig on a hoist. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted November 8, 2009 Share Posted November 8, 2009 Yeah, but if you want to really impress us try that set up without a hoist! Quote Link to comment Share on other sites More sharing options...
Mekanik Posted November 9, 2009 Share Posted November 9, 2009 We have had to do a number of wasted 3rd members, too. Overhaul was not really an option due to the damage. Wish the new one would come with a drive flange installed so you wouldn't have to mess with torqueing the nut. We fashioned a flat plate on a section of square tubing that slides over the end of our cherry picker. Just have to bolt the 3rd member by the flange to the plate and let the cherry picker handle the weight. Works well if you have the rig on a hoist. Tourqing that nut is SUCH a bitch. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted November 9, 2009 Share Posted November 9, 2009 I have ohauled one of these in an 07, not too bad a job. The complete 3rd member was 9000$ Couldnt even come close to cost capping it, mind you we had no carrier or case damage. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted November 9, 2009 Share Posted November 9, 2009 You can get a complete for $4000 here in the states. Quote Link to comment Share on other sites More sharing options...
