Customer with T444E
LARRY BRUDZYNSKI
I have been going back and forth with this customer. I think he has engine problems not fan clutch problems. Are there any of us in the Plymouth Ma. area I could refer him to. Read over my emails and see if I am going in the right direction. Thanks Guys......
The guys at the international dealership ask me for the last eight of the vin:
TH249832
The fan has a diameter of 24". It is a 7 blade fan.
I don't know if I mentioned it or if it matters but I am loing coolant out of the top of the coolant reservoir when the truck is at 210* or so. I make sure that it is not fllled past the maximum level and the reservoir will empty if I don't watch it daily.
Tx
Sent via BlackBerry by AT&T
-----Original Message-----
Date: Wed, 11 Nov 2009 11:51:46
To: <bob@weedandfeed.net>
Subject: RE: FanClutch.com Contact Form
Bob, How about the last 6 of the vin?
From: bob@weedandfeed.net [mailto:bob@weedandfeed.net]
Sent: Wednesday, November 11, 2009 11:13 AM
To: larry
Subject: Re: FanClutch.com Contact Form
Sorry I dont
Date: Wed, 11 Nov 2009 11:13:00
Bob, That number is incorrect but I was able to decipher which clutch it is.
Do you know what diameter the blade is?
Larry
Sent: Wednesday, November 11, 2009 10:29 AM
To: larry
This is what is etched into the housing for the viscous drive.
354098303. 19975
I can't be 100% sure of that because the numbers are faint and its hard to see them.
I will send you a photo in a separate email showing the fan/radiator assembly
Tx
Bob
Date: Wed, 11 Nov 2009 08:33:24
Bob, Are you available for me to call you?
Larry
Sent: Tuesday, November 10, 2009 3:30 PM
To: larry
Hi Larry
I had my mechanic flush the radiator. It is the original radiator to the truck. The fan is the original seven blade fan that came with the truck. I don't have the part number available for the viscous drive that I bought. It would be pretty difficult to find it at this point.
Bob
------Original Message------
To: Bob Mann
Cc: 'Paul Marek'
Sent: Nov 10, 2009 2:48 PM
Bob, I can help you out with this problem. I need some additional information though. You stated that you serviced the radiator. Was this re-cored or replaced? I will also need the numbers off of the Fan clutch and blade. There are severe duty parts available for IH trucks. This is a common problem with the split radiator applications.
Regards
Larry Brudzynski
Superior Fan Clutch & Blade Supply
3745 Central
Detroit,MI. USA 48210
1-313-842-4616 Ext 22
lbrudzynski@fanclutch.com
Sent: Tuesday, November 10, 2009 12:50 PM
To: info@FanClutch.com
Subject: FanClutch.com Contact Form
This form was just submitted from the FanClutch.com website.
First Name: Bob
Last Name: Mann
Address: 8 Meadow Park Rd., Unit #2
City: Plymouth
State: MA
Zip: 02360
Email: bob@weedandfeed.net
Phone: 508 509-4503
Message:
Hi
I have a 1995 International 4700 LPX with a T444E engine and Allison automatic transmission. The truck tows trailers ranging from 3000# to 15000# capacity. There is ample power to pull any load but I am having trouble with overheating. As you probably know, the radiator on this truck is split with 50% devoted to a transmission cooler, thus the radiator is especially small for a diesel engine. The truck will run somewhere between 190 and 210 if I baby the throttle and run the cab heater on high temperature and high fan settings. If I encounter hills or try to run faster than 55 mph the engine will quickly overheat. I serviced the radiator and installed a new viscous drive fan clutch (International OEM) earlier this summer with no relief. I have been poking around on internet forums and found that mechanics have had success in using the EC 450 product.
My question to you is do you offer a high output fan that I can install along with the EC 450 that will move more air through the radiator. I do not care how much horsepower it robs, how often it engages (can stay on 100% of the time as far as I am concerned) nor do I care how noisy it is - I just want to pull as much air as possible through the radiator.
Also, if you can think of any problems or pitfalls that I may encounter in retrofitting your product into my truck I would appreciate it
Tell him to put a new OE radiator in it.
Rusty Savignac owns a shop in Paxton, MA (near Worcester) about 1-1.5 hours away and has OE software, owns a DT and knows these trucks very well, plus he's a friend of mine. I've done classes for him and trust him completely. It's a small garage but very well equipped.
Paxton Garage
593 Pleasant St
Paxton, MA 01612-1382
(508) 756-0500
Yep, got your fax and am curious who's teaching them. I know Ken Buie (ex-GM trainer) teaches at Stark State, who is a great guy and excellent trainer. I called my Napa salesman and am waiting to hear back from him on details of the class.
(4 day LD diesel class, all makes, $795, 38 hours, at Stark State in Canton, promoted by NAPA)
