mrbudge Posted November 20, 2009 Share Posted November 20, 2009 Have a 2006 e-box here, 180000 km on it. Smokes blue on warmup while accelerating, usually at the end of second gear. At part throttle, 2200 rpm or so just before the shift to third if you hold it there it will blow clouds of blue smoke. If you accelerate harder it isn't so bad. Hot runs great. Starts ok, with minimal stiction. No dtc, fuel pressure 50psi under load. New oil and fuel filters. Has new egr valve and unison ring. PIDS look ok. One strange thing is during a neutral runup at 4000 rpm it will sometimes run a little rough and make some smoke, then clear up. I put some cetane booster in this afternoon and drove it, and am going to try it cold tomorrow. Anyone have some words of wisdom to share? Quote Link to comment Share on other sites More sharing options...
Jeff Clyde Posted November 20, 2009 Share Posted November 20, 2009 watch your FICM pids, had one that would stumble and smoke; Ficm m_power was dropping below 40v. Found poor connection at Ficm connector Quote Link to comment Share on other sites More sharing options...
cbriggs Posted November 21, 2009 Share Posted November 21, 2009 I have fixed 3 or 4 like this recently. All with 8 injectors. Holding it about 2200 to 2800 ish in park, you will probly be able to smoke out your whole lot. Quote Link to comment Share on other sites More sharing options...
