sam Posted November 24, 2009 Share Posted November 24, 2009 Hey guys, i have a 96 7.3 that the customer is staying it lack power. Went and drove it, seems fine, but kinda surges. Found a fuel leak at the lift pump and removed the fuel filter to see what it looked like. There is a black film on the walls of the housing. I looked thru the post to see if i could find where it has been talked about, but i am not having any luck. I do remember reading about it. I am leaning toward the injector orings but want to do more diag first. And i dont have a lot of experience with the 7.3, they seem to kick my butt from time to time... i guess i over think everything on them... but all help would be great... Thanks Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted November 24, 2009 Share Posted November 24, 2009 You stated that there is a film on the walls of the filter housing, how about the filter? More importantly how about the oil? Since a 1996 truck should have fuel return lines from the heads and back to the tank (if my memory serves me) leaking o-rings would allow engine oil to mix with fuel and in a 1996 truck the fuel in the tank and filter housing would be dark/black as well. Is the film oily or is it slimy and smell funky which would indicate a biological growth? Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted November 24, 2009 Share Posted November 24, 2009 Correct. If you would like some added reinforcement on the diag, disassemble the fuel pressure regulator and check for rubber chunkies inside, indicating the injector o-rings are bad. http://www.forddoctorsdts.com/forums/ubbthreads.php?ubb=showflat&Number=17694#Post17694 Good Luck! Quote Link to comment Share on other sites More sharing options...
