Fredsvt Posted December 3, 2009 Share Posted December 3, 2009 What's a realistic labor time to replace both the blower and main accessory drive belts on a 1999 SVT Lightning? Is the lower blower pulley a 14mm allen? My RealTime labor guide doesn't list it properly. I don't think .8 is quite enough. TIA Quote Link to comment Share on other sites More sharing options...
Adam_Dodson Posted December 3, 2009 Share Posted December 3, 2009 I ran into this a while ago on a Foose F150 with the roush charger. It has the same 2 belt setup with the braket and pulley that need to be removed to replace the accesory drive belt. I think it was about 3 hours but im sure I could cut an hour off if i did it again. As for the pulley im pretty sure i borrowed some contraption from JIM which was a bolt with a 14 or 13mm head welded to a socket. And i think it was left hand thread. Quote Link to comment Share on other sites More sharing options...
Fredsvt Posted December 4, 2009 Author Share Posted December 4, 2009 Thanks, I kind of figured. Pulling the fan, shroud and all the brackets is necessary. I do remember reading it's left hand thread. It's my truck, so I need to know how much time to leave open to do it. I made up a locking tool to go to a converter stud to the trans. I'll climb under/over it with some sockets this weekend to see what size the pulley bolt is. Quote Link to comment Share on other sites More sharing options...
OHNO60 Posted December 5, 2009 Share Posted December 5, 2009 THINK MTBELTANDHERECOMESTHEAUDIT- 14.0 WILL DO IT Quote Link to comment Share on other sites More sharing options...
