tecanic1 Posted June 15, 2006 Share Posted June 15, 2006 early 04 f350 third time back with p0401 first time clogged egr ..replaced and clean hole and map fitting retest ok..cust drove 2 weeks light back on ..retest p0401 ..retest all is working fine ..contact hotline and was advised to monitor iat 2 and then clean it and retest ...iat 2 was clogged and did make a difference after cleaning ..one week later light back on p0401 ..i am leaning to possible turbo issue ..any hints or fixes for this ..it has had all the updates and recalls...any helppppppppppppppppppp greatly appreciated Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted June 15, 2006 Share Posted June 15, 2006 MAF. Inspect it and replace if contaminated or even suspect contamination. I have been warned that cleaning them can leave a residue resulting in the concern continuing. I guess the sensor is just that sensitive. Also, I had a customer with a check engine light on and a P0401 that we determined was caused by an AFE intake and a Banks 4" turbo-back exhaust. Thats the only time I have seen that code. I would also look for leaks in the intake system, before and after the turbo. My little 2¢ Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted June 15, 2006 Share Posted June 15, 2006 Like Keith says, make sure it has an OE air filter housing on it. I had one with an aftermarket performance air cleaner setting EGR codes as a result of turbulence on the MAF. Reinstalling the OE housing fixed it. MAF reading is critical to the PCM for determining EGR flow. Tecanic: Has it had the 06E17 recall? I wonder how this affects this diag.... Good Luck! Quote Link to comment Share on other sites More sharing options...
sondogg12 Posted June 25, 2006 Share Posted June 25, 2006 command egr open and iat 2 should increase 30+ degrees. If not its prob a pluged egr cooler Quote Link to comment Share on other sites More sharing options...
