Bruce Amacker Posted December 16, 2009 Share Posted December 16, 2009 Hey Guys: I don't remember if we covered this topic or not. On the aluminum oil cooler cover casting there's a hole that's drilled partially through but not all of the way through. There's a threaded hole in the block under this casting hole. Why is this hole not completed? Is it possible to drill this through and put a bolt there? I've got one leaking at this exact spot..... Thanks! Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted December 17, 2009 Share Posted December 17, 2009 If I remember right, that's the spot where the oil/fuel filter housing overhangs and gets in the way, thus no bolt. Quote Link to comment Share on other sites More sharing options...
