Balloon Test
Quote:
For better results try the Compression Bubble Test. Observe the video to the right. Simply remove the secondary filter cap and filter, then top off the housing with fuel just above the standpipe. Pressing down on the bypass valve on top of the standpipe wont open the valve because it has to interlock with a filter before it will move but it should open just enough to allow air to exit. You may also remove the green o-ring at the top of the standpipe but YOU MUST remember to reinstall it after performing this test! Using a remote starter switch, crank the engine with the IGNITION KEY IN THE OFF POSITION. Observe the filter housing watching for any air bubbles coming from the standpipe. The motion of the engine cranking may make bubbles difficult to see. Stop cranking the engine and residual bubbles may still be seen for a few seconds. The presence of air bubbles indicates that a combustion leak exists but this will not help identify a particular cylinder or cylinder bank. Usually, that information is already known from other test data. If you have performed the Balloon Test you will find this method much easier and more effective. Save the balloons for a party.
I was just reading the excellent article on the combustion bubble test.
I just want to add my opinion on this method. An additional step that I do is to completely remove the plastic stand pipe inside the filter housing, there are 2 small torx screws and a o ring. You will then see the 2 passages that go to each cylinder bank. Jump the starter to crank the engine, then you can look at the small passages to see which cylinder bank the air is coming from.
I understand the power balance test will give you a good indication of which bank is giving the trouble, but watching for bubbles gives you solid proof that air is causing the problem.
  • 3 weeks later...
Correct me if I'm wrong:
Remove FF
Disable FP
Crank engine by bypassing the starter
Observe bubbles in FF, or balloon growing
To identify which cylinder, remove all glows plug except one on the affected bank
Crank engine
Move glow plug until problem reoccurs- you've found the bad boy.
Correct. If you cannot run the engine and run the power balance test to try narrowing it down to a cylinder you must perform the balloon test... err... that test only works with a REALLY bad injector. We have discussed removing the secondary filter, topping off the housing and watching for air bubbles in the fuel while cranking. THEN, removing glow plugs one by one will help identify the offending cylinder. If you have misfire codes for one bank or power balance indicates multiple cylinders on one bank start there.
