Bruce Amacker Posted December 30, 2009 Share Posted December 30, 2009 RE: 2006 6.0 HP o-rings Hey guys, what's the current situation regarding availability of HP oil standpipe o-rings and HP W-manifold dummy plug o-rings. I'm trying to help a guy whose dealer says no o-rings are available, only replacement parts with o-rings attached. Old info from my notes, all PN's are NLA: W302290 are the small rings on the bottom of the stand pipe and the bottom of the 2 piece stand pipe.W301386 is the ring at the top of the dummy plug and the top of the 2 piece stand pipe. W301390 is the ring in the middle of the 2 piece stand pipe and the bottom of the dummy plug. 6.0L Diesel Stand Pipe O-Rings: Now Only Available in KitsO-Ring part numbers W301386, W301390 & W302209 are no longer available per Ford Diesel Engineering. The O-Rings are now included in the Stand Pipe assembly (base 9A332) or the Stand Pipe Plug (part number W302195). Alliant Power has a bulletin (APTB 03/08) on these with (I think) FMC PN's that match what I have in my notes, but are NLA from Ford. Are they available from AP? Are these available from FMC? How about Alliant? If so, what are the PN's? Thanks! Quote Link to comment Share on other sites More sharing options...
Aaron Posted December 30, 2009 Share Posted December 30, 2009 Shows the hardware numbers as Unavailable as per our parts manager -- I think there was an SSM or Broadcast message regarding the availability of the O-rings, they were going to service them only as standpipe/plug/etc. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted December 30, 2009 Share Posted December 30, 2009 I know there is documentation to this effect: the standpipe o-rings are no longer serviced separately. You MUST install a standpipe kit that includes the standpipes, dummy plugs and a couple of loose seals. Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted December 30, 2009 Share Posted December 30, 2009 Bruce Amacker said: Alliant Power has a bulletin (APTB 03/08) on these with (I think) FMC PN's that match what I have in my notes, but are NLA from Ford. Are they available from AP? Are these available from FMC? How about Alliant? If so, what are the PN's? Thanks! It doesn't look like they are available seperately.... http://www.alliantpower.com/pdf/APTB-0308R1-watermark.pdf Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted December 30, 2009 Share Posted December 30, 2009 6E7Z-9A332-B As I recall this kit services both the 4.5L and the 6.0L Quote Link to comment Share on other sites More sharing options...
BrunoWilimek Posted December 31, 2009 Share Posted December 31, 2009 I suspect the reason they say to replace the whole standpipe is due to repeat repairs that were caused by techs failing to wait for the d-rings to settle in after being stretched to go on the pipe. The manual used to specify a wait to install time. One of the techs here keeps a set in his box and if I need to do a quick repair and a standpipe is not in stock, I borrow them and get parts to replace them to him, so they must still be available separately. Quote Link to comment Share on other sites More sharing options...
blown99 Posted December 31, 2009 Share Posted December 31, 2009 They are not available on the international side either. We replace the crankcase to head tube to the updated unit and replace the dummie plugs. About $175 tube kit that you can't get o-rings for is a bit ridiculous. Quote Link to comment Share on other sites More sharing options...
