Programming in keyless entry
GregH
We've got a batch of 2009 police cars here that were ordered without keyless entry. Now they have decided they want that function.
We messed around with flashing another configuration into the DDM and got keyless entry to work with standard remotes! Unfortunately, we also triggered a tire pressure monitor problem.
Turns out that the steel wheels on this vehicle take different sensors than the aluminum wheels from our donor car.
So, anyone know where we can find the as-built data for the DDM of a 2009 CV with keyless entry and steel wheels?
I don't know how much this will help, but we have one here right now that has steel wheels. Here's the data:
Module Reprogramming
VIN: 2FAHP71V49X116856
Vehicle Data: 20F0 7737 FFBD
Click here if module data required is not available below
Module Information Found
When prompted, be sure to save or copy the file to the following IDS directory:
c:\Program Files\Ford Motor Company\Calibration Files
PCM Module
PCM 1 FFFF FFFF 020F
PCM 2 FF0D 14FF FF30
PCM 3 FFFF 0FFF FF1E
PCM 4 FFFF FFFF FF0F
PCM 5 FFFF FFFF FF10
PCM 6 FFFF FFFF FF11
PCM 7 FFFF FFFF FF12
PCM 8 FFFF FFFF FF13
PCM 9 FFFF FFFF FF14
BCE Modules TSB SSM Instructions
A0-01 29F3 F527 01DA
A0-02 29F3 F601 01B6
A0-03 29F5 2445 012B
A0-04 29F3 F51C 01D2
A0-05 2000 0000 00C5
A0-06 2323 2300 000F
A0-07 0000 0000 04AB
A0-08 2815 D400 00B9
58-01 3030 3032 4661
58-02 4148 5037 319B
58-03 5634 3958 31A7
58-04 3136 3835 3666
70-01 F71C 0000 FF83
720-01-01 1280 0000 BB
760-01-01 3246 4148 50BA
760-01-02 3731 5634 3995
760-01-03 5831 3136 3893
760-01-04 3536 0800 00DF
760-01-05 0000 0000 006D
760-01-06 0000 02FC 006C
End of As Built information
FCXWS447
Did 9X116856 have keyless entry?
I flashed in that data, and the keyless entry system stayed deactivated....
Do you mean keyless entry as in a factory driver door equipped keypad, or a remote?
