jw33 Posted March 4, 2010 Share Posted March 4, 2010 I usually pull cab for head gaskets but cant on this one,can you install head studs with the body on? Quote Link to comment Share on other sites More sharing options...
Adam_Dodson Posted March 4, 2010 Share Posted March 4, 2010 i dont think you will get a torque wrench on the rear lower bolt on the drivers side without lifting the cab at least a few inches? Quote Link to comment Share on other sites More sharing options...
Aaron Posted March 4, 2010 Share Posted March 4, 2010 I think you'll have a hard time getting the studs in the rear of the left side, but it can probably be done. I have a similar situation here right now. Quote Link to comment Share on other sites More sharing options...
jw33 Posted March 4, 2010 Author Share Posted March 4, 2010 i kinda remember reading something a while back about taking the trans mount loose and jacking the rear of engine up, ill guess ill find out shortly Quote Link to comment Share on other sites More sharing options...
joshbuys Posted March 5, 2010 Share Posted March 5, 2010 had a guy I worked with at my old dealership do this on a truck - just make sure you have the rear stud in question in the head/rocker box assembly as you put the head on - other than that - not much different than doing bolts on it. have fun!!!! Quote Link to comment Share on other sites More sharing options...
jw33 Posted March 9, 2010 Author Share Posted March 9, 2010 jacking the trans up worked like a charm Quote Link to comment Share on other sites More sharing options...
Aaron Posted March 10, 2010 Share Posted March 10, 2010 i dont think you will get a torque wrench on the rear lower bolt on the drivers side without lifting the cab at least a few inches? I don't know if the body mounts/motor mounts/etc are any different, but I have a 07 F-450 or 550 apart right now and there is TONS of room at the rear on the driver's side head bolt. This one had to be done cab on since there is a dump box over top of the cab. I took that bolt out with a standard breaker bar and mastercraft 18mm chrome socket. Nothing special to it at all. I'm wondering if this is any different access wise because it's a cab & chassis or what. Quote Link to comment Share on other sites More sharing options...
xXCMGXx Posted March 11, 2010 Share Posted March 11, 2010 i dont think you will get a torque wrench on the rear lower bolt on the drivers side without lifting the cab at least a few inches? Ive never had to lift the cab to torque that rear lower bolt. You must have one fatass torque wrench! Quote Link to comment Share on other sites More sharing options...
joshbuys Posted March 11, 2010 Share Posted March 11, 2010 Originally Posted By: Adam_Dodson i dont think you will get a torque wrench on the rear lower bolt on the drivers side without lifting the cab at least a few inches? Ive never had to lift the cab to torque that rear lower bolt. You must have one fat* torque wrench! +1 NEVER HAD A PROBLEM TORQUING IN CAB - I LIKE THE NEW SNAP-OFF TOOL, BUT I'VE ALWAYS BEEN ABLE TO FIT MY TORQUE WRENCH IN THERE! Quote Link to comment Share on other sites More sharing options...
