Mekanik Posted March 13, 2010 Share Posted March 13, 2010 The first two I had, it seemed like the turbo down-pipe just fell out. The last two I have done I had to really fight to remove and then install the down-pipe. The one I did this morning, I left the down-pipe in the vehicle and moved it around while I replaced the up-pipe. It was still a bitch. Does anyone have any tricks for removing the down-pipe and up-pipe on these things? I do remove the nut for the battery cable on the starter and I think that helps a little. I do know one tech that removes the body when doing this job. Guess what my next job is? Yep, it's another right side up-pipe. I shouldn't be complaining though, I do make good time on them. Quote Link to comment Share on other sites More sharing options...
Aaron Posted March 13, 2010 Share Posted March 13, 2010 With the trans out, does the engine tilt back slightly and bind up on the exhaust? Maybe if you put a stand under the oil pan it would help some? Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted March 13, 2010 Share Posted March 13, 2010 I've never had a problem getting the down pipe out. Are you trying to do it with the transmission in place? Remove the body?? Really?? I figure the 20 minutes it takes to remove the transmission is way quicker. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted March 13, 2010 Share Posted March 13, 2010 Last one i did i had to push up on the front of the engine with a tall jack stand, then downpipe (literaly) fell out. Also i think removing egrt sensor helped. It was a while ago. Quote Link to comment Share on other sites More sharing options...
Aaron Posted March 13, 2010 Share Posted March 13, 2010 ^^^^ That's what i was trying to say. Quote Link to comment Share on other sites More sharing options...
joshbuys Posted March 13, 2010 Share Posted March 13, 2010 I've never had a problem getting the down pipe out. Are you trying to do it with the transmission in place? Remove the body?? Really?? I figure the 20 minutes it takes to remove the transmission is way quicker. +1 Quote Link to comment Share on other sites More sharing options...
Mekanik Posted March 13, 2010 Author Share Posted March 13, 2010 With the trans out, does the engine tilt back slightly and bind up on the exhaust? Maybe if you put a stand under the oil pan it would help some? That's what I was thinking when I was taking the second one apart yesterday. What I did was removed the top bellhousing bolts, and then I tilted the back of the trans as high as it would go. Then I modified a 2X4 and wedged it beetween the oil pan and the frame. The down-pipe came right out. No problems at all. Quote Link to comment Share on other sites More sharing options...
robp823 Posted April 1, 2010 Share Posted April 1, 2010 nice Quote Link to comment Share on other sites More sharing options...
leon Posted April 14, 2010 Share Posted April 14, 2010 what is a legitimate time to charge out on these under cp? if I read the slts correctly it is 6.3 warr. time is that correct? Quote Link to comment Share on other sites More sharing options...
fordtech03 Posted April 15, 2010 Share Posted April 15, 2010 I believe that is correct for warranty time. Quote Link to comment Share on other sites More sharing options...
