robp823 Posted March 31, 2010 Share Posted March 31, 2010 Will a P040D cause the engine to derate???? Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted March 31, 2010 Share Posted March 31, 2010 Yes it will. Make sure you can get the EGR temp sensor A loose before you order parts... You may end up putting a new right up pipe in it if it doesn't come out in one piece. Quote Link to comment Share on other sites More sharing options...
robp823 Posted March 31, 2010 Author Share Posted March 31, 2010 Yea i ve been there before.Dammit! I just got finished putting the cab back down on this thing for a total different issue. Quote Link to comment Share on other sites More sharing options...
Aaron Posted March 31, 2010 Share Posted March 31, 2010 YES and before the code sets the sensor can go enough out of range to cause a De rate that's nearly impossible to duplicate, as well as there is no info provided to the driver that the truck is de-rating, according to the hotline. BTDTGTTS as Bruce would say Quote Link to comment Share on other sites More sharing options...
robp823 Posted March 31, 2010 Author Share Posted March 31, 2010 i went to test drive it and it was guttless.Then cel came on.Thought, actually was hoping i just forgot to plug something in but nooooooooooooo! fml Quote Link to comment Share on other sites More sharing options...
Aaron Posted March 31, 2010 Share Posted March 31, 2010 It's not that bad of a sensor to change. Pull the inner fender, heat the piss out of the bung in the pipe, and wind 'er out. Quote Link to comment Share on other sites More sharing options...
robp823 Posted March 31, 2010 Author Share Posted March 31, 2010 well i got lucky arron.When i went to disconnect the sensor the wire fell out of the back of the connector.Found the same connector pin in a 6.0 harness i had laying around soldered in the wire and it was good to go. Quote Link to comment Share on other sites More sharing options...
Aaron Posted April 1, 2010 Share Posted April 1, 2010 Gotta like 'er! Quote Link to comment Share on other sites More sharing options...
