robp823 Posted April 12, 2010 Share Posted April 12, 2010 Does anyone know how to update the PCM in F-650 with 6.0.Do you use the MD software or IDS or combination of both.Got one here that is a dog till it warms up.Just want to make sure it has the update for cycling the spool valves.Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted April 12, 2010 Share Posted April 12, 2010 MD Truck Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted April 12, 2010 Share Posted April 12, 2010 NETS is the program, and flashing it did fix the cold performance problem on a F650 we did lately. http://www.forddoctorsdts.com/forums/ubb...=true#Post27727 Good Luck! Quote Link to comment Share on other sites More sharing options...
robp823 Posted April 12, 2010 Author Share Posted April 12, 2010 just flash it and it will automaticly update?Thanks Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted April 12, 2010 Share Posted April 12, 2010 IIRC, we pulled the flash out with NETS, (it's called a "get") sent it to Ford, they massaged it, sent it back to us and we installed it with NETS. It did fix the problems and made the trucks run considerably better! Keith- is that how Ford does it usually? Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted April 12, 2010 Share Posted April 12, 2010 Yes sir! But I believe the data is sent to Navistar, not Ford. * I THINK * You will need a NETS user name and password to perform the reprogramming which you can get by calling the Ford Hot-Line. Quote Link to comment Share on other sites More sharing options...
robp823 Posted April 13, 2010 Author Share Posted April 13, 2010 yes i have the user name and password and ive done a get/send before.I was just curious has to how it updates it.I guess when you do a get you automatically get the latest versions. Quote Link to comment Share on other sites More sharing options...
RichMichels Posted May 23, 2013 Share Posted May 23, 2013 I know this is a old post, did the reflash work with Navistar computer or did you have to log into Ford for the file? We have a '03 650 6.0 in the shop that's running bad. Need to check if it's up to date? Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 23, 2013 Share Posted May 23, 2013 Do you have a Navistar scan tool like MD Truck in your shop? You will need to download NETS from the Rotunda website and you will need a username and password from Ford... call the Hot-Line... Quote Link to comment Share on other sites More sharing options...
RichMichels Posted May 23, 2013 Share Posted May 23, 2013 We have master diagnostic's, We have Net's, but I believe it's a Navistar version? It connects to Navistar's engine files. I'm guessing that Ford has their own files on their own servers? I'll look at the Rotunda site, the link in the resource section ask's for a password, do you know of another web page that'll get to the correct area? I'll try the hotline Thanks,,,, Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 23, 2013 Share Posted May 23, 2013 That's a negative on Ford having the files... NETS connects to International for the files and as far as I know that has not changed. So if you have MD Truck + NETS + username and password that is all you need. Like I said, if you don't have a username and password or you have forgotten your information just run OASIS and contact the Hot-Line using the form. I had to and it didn't require a phone call. Quote Link to comment Share on other sites More sharing options...
RichMichels Posted May 26, 2013 Share Posted May 26, 2013 Just a update to help the next guy out,,, I am a Navistar tech, I was able to use my log in (Navistar DYY number) and password with Navistar's NETS to download and reprogram a ECM on a '04 F-650. The Navistar server accepted the VIN, and the file came back with the correct engine serial number. It appears that both Ford's and Navistar's nets are the same except for each has their own logo's embedded on the pages. This truck ran rough and smoked black,with no codes. Two other shop's had worked on it before it came to us. One installed a new set of injectors, the other a new turbo. We tested the IDM (FICM)voltages @ 47.5V and installed a EBP sensor, the old one was biased, it still acted up after replacement. After the re-flash it quit smoking and ran smooth. Thanks to this forum for helping solve this problem! Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 26, 2013 Share Posted May 26, 2013 Thanx for the feedback Rich! Quote Link to comment Share on other sites More sharing options...
