Mbl35 Posted April 13, 2010 Share Posted April 13, 2010 We just had a bedplate put in under warrenty at the dealer. 06 e350 box ambulance. A peice of the bedplate was broke off were the oilfilter housing bolts to. Anyway when this thing came back like a month later with no reverse lights, oil pressure gauge drops to zero at times and a diesel leak. I repaired the diesel leak-copper fuelline gasket had a nail line in it causing a fine stream. I pushed on the oilpressure switch connector with a long screwdriver and that temporarily stoped the oil pressure gauge from dropping oh AND MOST IMPORTANTLY A HOLLOW SOUNDING KNOCK SOUNDING LOUDEST FROM THE AIRFILTER AREA. It went back to the dealer and they repaired the oilpressure switch/guage concern and some loose brackets and nissing bolts from the ps pump etc. But now when i came in last nite to find it in the bay with a note saying no revberse lights. It had a check engine light with trans codes and all bank 1 glowplug circuit codes and the knock was still there! Starting with the no reverse lights problem, verifying the chasis circuit being good at the relay i went to the trans snake at the pcm following rearwood to find the little 2 pin connector that connects to the engine harness unpluged-ok checked it and rev lite problem fixed. On to next concern-or should i say problem...glowplug, i see the glowplug harness connectors have a shitload of tape wrapped around them. Also bank 1 glowplug harness is installed backwards. Now being so irate-i snake my hand from the rear of the engine and unwrap the tape and yank the glowplug harness out and rnr , glowplug test proves out-fixed. On to next problem-transmission, i inspect wiring down to trans main connector at trans to find a caves in pin and so flattened that i did'nt attempt to straighten it. I rnr inner trans connector harness and test drive 25 miles all Pass-runs like new now EXEPT(sorry for the long rant but i'm pssed off man)FOR THE KNOCK AT IDLE! I also checked for loose crankpulley bolts etc. and all are tight. The dealer said to remove the brakebooster vacuum line and see if it goes away, i did that and not likely. That knock was not present before the bed plate repair. Though i would like to know if anyone has experienced a knock like this from the left front of the moter and i t seems to get louder the longer the engine idles. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted April 13, 2010 Share Posted April 13, 2010 My experience with a knock coming from the air filter has usually been valvetrain related: valve tip trashed, rocker broken, crosshead, seized guide, etc. How's the balance graph and IDS compression test? How about killing the cyls one at a time and see if it changes? I might suggest an oil analysis if nothing else checks out (Napa/Wix 4077, $14). The scope wizards would use a pressure sensor in the intake manifold to graph out intake manifold pulses, indicating a mechanical problem but I've only done this a couple of times. The sensor is called First Look. AND MOST IMPORTANTLY A HOLLOW SOUNDING KNOCK SOUNDING LOUDEST FROM THE AIRFILTER AREA. Good Luck! Quote Link to comment Share on other sites More sharing options...
