05 cylinder head
Also, I don't know what catalog your particular store uses, but if I remember rightly...i THINK the last one I had looked up told me in the part description what dowels the motor had, then came with both sizes anyhow.
Home heads use a T45 injector hold down bolt and M10 Rocker Bolts, and some use a T40 and M8. These different bolts mean different machining! THIS is what you really need to be looking at!
Here's the TSB that will help you to determine what you need.
I thought the early/late hold down stuff was only 03-04, guess I was wrong.
I have had pretty good luck with the parts department on these, getting the right stuff on the first order. Wierd, I know Posted Image
