robp823 Posted April 21, 2010 Share Posted April 21, 2010 Have any of you guys run into the HP pump gasket leaking oil? Quote Link to comment Share on other sites More sharing options...
rlchv70 Posted April 21, 2010 Share Posted April 21, 2010 More likely, it's the turbo drain. Quote Link to comment Share on other sites More sharing options...
joshbuys Posted April 22, 2010 Share Posted April 22, 2010 NEVER SEEN ONE LEAKING, SEEN A COUPLE TURBO DRAINS LEAKING. Quote Link to comment Share on other sites More sharing options...
robp823 Posted April 22, 2010 Author Share Posted April 22, 2010 Yea,all i could really see with the heat shield off the turbo and the intake elbow off was around the oil cooler and that was dry.But if you get under the truck and look up the back it looks like its seeping right of the HP pump gasket.Im sure your right though,either way its gotta be fixed.Thanks Quote Link to comment Share on other sites More sharing options...
cbriggs Posted April 24, 2010 Share Posted April 24, 2010 Has the rear cover ever been off? I have seen the hp pump gasket get torn when slipping in the rear cover. BTDTGTTS Quote Link to comment Share on other sites More sharing options...
robp823 Posted April 25, 2010 Author Share Posted April 25, 2010 nope rear cover never off.Got the cab off and it was def the turbo drain. Quote Link to comment Share on other sites More sharing options...
