cheldmann Posted May 5, 2010 Share Posted May 5, 2010 Got an 03 turbo seaping oit from the exhaust side. Bearing doesnt have excessive play. Ive heard international has rebuild kits for these. called 2 dealers and they dont want to help cause its a ford. Anyone know the part number for their rebuild kit? thanks Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 5, 2010 Share Posted May 5, 2010 I know "rebuilding" would be cheaper but on a 7 year old turbo why wouldn't you recommend replacing the CRH? If there IS something else wrong with the shaft or bearing you will be eating the repeat repair not to mention the reman housing has a 12/12 warranty. Just askin. And I am sure if you dig hard enough you will find a kit... Where's LARRY? Quote Link to comment Share on other sites More sharing options...
cheldmann Posted May 5, 2010 Author Share Posted May 5, 2010 Its my truck. i have it completley disassembled and theres no play or wear on the wheels or shaft, housing is fine, cam moves freeley. Thats probly all they don to a chra anyway, half of them are bad out of the box here latley too. like i said all its doing is seaping oil a tiny bit. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 5, 2010 Share Posted May 5, 2010 Well it is a little different when it is your own truck... Quote Link to comment Share on other sites More sharing options...
blown99 Posted May 6, 2010 Share Posted May 6, 2010 I work for an international dealer and am not aware of any turbo rebuild kits for that turbo. They stopped offering individual pieces for turbos many years ago. I think the 6.0 turbo is based on a gt38. If so, then a standard seal and bearing kit would work. I would try bullseye power. http://www.bullseyepower.com/contactus.asp You give them the dimensions of the parts you have and they will supply you with the correct repair kit. Maybe you are thinking of the turbo reconditioning kits that international offers to repair rusty and sticking exhaust housings? Quote Link to comment Share on other sites More sharing options...
cheldmann Posted May 6, 2010 Author Share Posted May 6, 2010 FML so you guys dont ever pull the shaft out and replace bearings or seals? i thought ive read several times that what they did at international. oh well, i think i found a kit from garret i just need a tax id to get it so il have to get my parts dept to order it. thanks Quote Link to comment Share on other sites More sharing options...
Aaron Posted May 7, 2010 Share Posted May 7, 2010 I know I don't do it, personally... Typically if I've got a turbo off, the CHRA is fucked anyway, so it gets one of those, and typically a new unison ring, usually the actuator cam has worn the slot in the ring into a + sign. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted June 24, 2010 Share Posted June 24, 2010 Just out of curiosity what do you guys charge for a unison ring customer pay? Part price. Quote Link to comment Share on other sites More sharing options...
GregKneupper Posted June 25, 2010 Share Posted June 25, 2010 167.00 Quote Link to comment Share on other sites More sharing options...
mchan68 Posted June 25, 2010 Share Posted June 25, 2010 Just out of curiosity what do you guys charge for a unison ring customer pay? Part price.What is exactly is the point to this question? Are you thinking that the price of the unison ring is a little astronomical, perhaps? If so, I couldn't agree more. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted June 25, 2010 Share Posted June 25, 2010 Yes mike, that is exactly my point and I can't remember shit apparently. Yesterday I priced out a unison ring for a customer pay repair (not common for me) and I was shocked that that metal ring was $161.00! I concede that the part has some machining involved that requires accuracy, but wow!!! I know, I know. Diesels are expensive. Quote Link to comment Share on other sites More sharing options...
Fordracer Posted June 25, 2010 Share Posted June 25, 2010 I was talking to Larry the other day about rebuilding turbos and he said you can have a machine shop machine a new slot on the other side of the unison ring. Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted June 26, 2010 Share Posted June 26, 2010 A reputable machine shop can machine a new slot for about 30-35 dollars. Usually about a hour depending on how busy they are. The pivot shaft on the other hand is something else. If it's worn your shit out of luck. We have tried welding and remachining, chroming, ceramic coating nothing works, the heat treat on that shaft doesn't take well to repairs. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted June 26, 2010 Share Posted June 26, 2010 Yes mike, that is exactly my point and I can't remember shit apparently. Yesterday I priced out a unison ring for a customer pay repair (not common for me) and I was shocked that that metal ring was $161.00! I concede that the part has some machining involved that requires accuracy, but wow!!! I know, I know. Diesels are expensive.Keith, you think that's outrageous. How about $277.00?. And I thought we were supposed to be dollar for dollar between US and CDN. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted June 26, 2010 Share Posted June 26, 2010 IH 1884220C1 $238 list $220 net Quote Link to comment Share on other sites More sharing options...
Aaron Posted June 26, 2010 Share Posted June 26, 2010 I was gonna say, the last one I priced out was like $275 from Ford here in Canada. Quote Link to comment Share on other sites More sharing options...
Aaron Posted June 26, 2010 Share Posted June 26, 2010 Gonna have my buddy start running them off on his water jet, and make the hole in the center about .005 larger so it doesn't grab the CHRA as readily as it seems to. Quote Link to comment Share on other sites More sharing options...
