mchan68 Posted May 18, 2010 Share Posted May 18, 2010 Can anyone give me a WPT part number for wiring pigtail needed for this part please? My parts guy and I have searched both Microcrap and the Motorcaft catalogue with unsuccessful results. This is obviously different from the original below: The part in question, is the automatic park brake release solenoid on a 2003 Lincoln Navigator. Quote Link to comment Share on other sites More sharing options...
BrunoWilimek Posted May 21, 2010 Share Posted May 21, 2010 Do you know the connector number? I can't seem to find the Parking brake control in the wiring diagrams, however, If you knew the connector number, you could try looking in a newer online wiring diagram, then this type of information is available if you go to view the connector face. This is a parking brake switch on a 2009 Navigator used as an example only. Good luck. Connector: C2015 Description PARKING BRAKE SWITCH Color BK Harness 14A005 Base Part # 15A851 Service Pigtail F5VB-14489-EA The reason for going to a newer year is twofold, 1.This info is not available on older diagrams and 2.The new switch is likely a change-up part as used in later models and they have superceded the old part with the later part to save costs, requiring you to come up with an adapter or revised connector. This has happened in the past, if you remember the revised wiper motor coming out on early 1990's F150's that bolted on but required an adapter harness to mate to the wiring harness. Another example is the cruise de-activation switch recall with the jumper harness to mate with a revised switch if the terminal connector was damaged with brake fluid. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted May 22, 2010 Author Share Posted May 22, 2010 Do you know the connector number? I can't seem to find the Parking brake control in the wiring diagrams, however, If you knew the connector number, you could try looking in a newer online wiring diagram, then this type of information is available if you go to view the connector face. This is a parking brake switch on a 2009 Navigator used as an example only. Good luck. Connector: C2015 Description PARKING BRAKE SWITCH Color BK Harness 14A005 Base Part # 15A851 Service Pigtail F5VB-14489-EA The reason for going to a newer year is twofold, 1.This info is not available on older diagrams and 2.The new switch is likely a change-up part as used in later models and they have superceded the old part with the later part to save costs, requiring you to come up with an adapter or revised connector. This has happened in the past, if you remember the revised wiper motor coming out on early 1990's F150's that bolted on but required an adapter harness to mate to the wiring harness. Another example is the cruise de-activation switch recall with the jumper harness to mate with a revised switch if the terminal connector was damaged with brake fluid. Been there, done that already. And in answer to your initial question that would be C2132 for a 2003 Navigator, which happens to be the same connector number for model years up to 2007. On the later model years that include that much detail when navigating to the connector face page, it listed a WPT number as NOT AVAILABLE. But thanks anyway Bruno. Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted May 23, 2010 Share Posted May 23, 2010 Do you have a part number or an engineering number that might help? For the actuator - I mean... Quote Link to comment Share on other sites More sharing options...
