STROKER_T Posted May 24, 2010 Share Posted May 24, 2010 Hey guys...got an '06 e350 w/ a 6.0(church bus)here...it's got a big 14,000 miles on it,the a/c compressor is locked tight,the clucth disc is WHITE... The church has got no funds for affording the a/c compressor,orfice tube,accumulator,and flush,and let's not forget labor... Is there a bypass pulley w/ bracket available for this thing and where could such a part be obtained in a timely fashion...they're gonna fix it,just not at this time.... Came in for a no start,a/c compressor is causal part,14,000 miles.... Thanks for any and all advice... Quote Link to comment Share on other sites More sharing options...
STROKER_T Posted May 24, 2010 Author Share Posted May 24, 2010 Ok....what if one were to remove the clutch disc along with pulley/coil...then reinstall just the pulley w/ snap ring....? Temporarily...of course... Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 24, 2010 Share Posted May 24, 2010 I don't think I have seen Ford use a dummy pulley in quite a few years. Regarding the removal of the clutch disk that might work but on many of the compressor failures I have run into lately the pulley bearing has been wiped out from the field clutch overheating. Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted May 25, 2010 Share Posted May 25, 2010 How about unplug the field coil and replace pulley as necessary? Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted May 25, 2010 Share Posted May 25, 2010 Now... I'm not a religious man... but I try to live my life "right". I try to be careful with my donations... obviously Crohns and colitis should get the bulk of my generosity... At the same time, I am ever thankful for my good fortune. I always try to remember to add something to the grocery basket to drop in the food bank bin on the way out of the store.... And I often cut deals for those on fixed incomes or otherwise disadvantaged. Could this be a good opportunity to make a donation? Quote Link to comment Share on other sites More sharing options...
slim Posted May 25, 2010 Share Posted May 25, 2010 If they really are hurting, I'd remove the clutch disc, field, and pulley then reinstall a new pulley only. That will keep them going and if you feel generous you could give em a break on the labor. You reap what you sow or something like that. I'd think they would be back pretty soon since your in South Carolina. Nothing quite like a hot bus full of people in their Sunday best. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted May 25, 2010 Share Posted May 25, 2010 The part number for the dummy pulley and bracket assembly that takes the place of the AC compressor for non-AC equipped applications is 4C2Z-8678-AA or YS-305. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 25, 2010 Share Posted May 25, 2010 Mike you are a rockstar! Quote Link to comment Share on other sites More sharing options...
mchan68 Posted May 25, 2010 Share Posted May 25, 2010 Mike you are a rockstar! I appreciate any support I can get from this website on difficult situations, so I don't mind helping whenever possible. Quote Link to comment Share on other sites More sharing options...
jimmy57 Posted May 25, 2010 Share Posted May 25, 2010 How about a core compressor swap. Put a bad one on it that has good pulley bearing and send theirs in for the core instead. I imagine same amount of work involved to remove and fit the dummy as to remove and fit another compressor with no charging or other service. Quote Link to comment Share on other sites More sharing options...
Aaron Posted May 26, 2010 Share Posted May 26, 2010 Dammit...I coulda been a rockstar had I only been here earlier LOL. I just looked this up the other day at work for a similar situation, but it's a cube truck and "It don't need any damn air" Microcat sucks, by the way. Quote Link to comment Share on other sites More sharing options...
