iceman Posted June 22, 2010 Share Posted June 22, 2010 can you remove and install a #1 cylinder injector cup with out removing head? Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted June 22, 2010 Share Posted June 22, 2010 Yes, on an F-model. Why are you changing it? I usually suggest them in sets..... Quote Link to comment Share on other sites More sharing options...
iceman Posted June 22, 2010 Author Share Posted June 22, 2010 bruce my coworker replace a long block 5400miles ago came in running rough and found injector cup #1 cracked at bottom were copper washer seals due to the injector was not properly torqued during engine manufaturing Quote Link to comment Share on other sites More sharing options...
eastendpowerstroke Posted June 23, 2010 Share Posted June 23, 2010 In an F-series no problem if it's a Econoline no. Quote Link to comment Share on other sites More sharing options...
batmantech Posted June 23, 2010 Share Posted June 23, 2010 - Quote Link to comment Share on other sites More sharing options...
joshbuys Posted June 25, 2010 Share Posted June 25, 2010 Make sure you drop a dime in the bottom of the cup before you start running the tap in - it will keep the shavings out of the cylinder! Quote Link to comment Share on other sites More sharing options...
Aaron Posted June 26, 2010 Share Posted June 26, 2010 If you are doing it warranty, make sure you have a head gasket and bolt set to return, they are gonna ask for it since WSM procedure says to take the head off to replace the cups. Quote Link to comment Share on other sites More sharing options...
