f-550 rear wheel bearing
Working on an 05' F-550. I am replacing the rear pads and rotors. Since you have to remove the hub to get the rotor off. I was wondering if somebody could help me out with some specs, I forgot my service information discs at home. I am looking for the rear wheel bearing adjusting spec, as well as torque specs for the rotor bolts, caliper bracket bolts, and caliper bolts themselves. I was just going to use standard bolt torque for those but the wheel bearing adjustment procedure would be much appreciated. Thanks in advance guys.
This information is for a 2005 F450/550
To adjust the bearings...
    [*]Tighten to 95 Nm (70 lb-ft).
    [*]Back off the hub nut 90 degrees.
    [*]Tighten to 24 Nm (18 lb-ft).
    [*]Final bearing adjustment has zero end play. The maximum torque to rotate the hub is 2.3 Nm (20 lb-in) when end play is zero
Rotor to hub bolts - 155 Nm (114 lb-ft).
Axle shaft bolts - 133 Nm (98 lb-ft).
Caliper bracket to axle bolts - 400 Nm (295 lb-ft).
Caliper to caliper bracket bolts - 62 Nm (46 lb-ft).
