Keith Browning Posted August 3, 2010 Share Posted August 3, 2010 I know this is old news but it seems to be missing from our forum. I have never had the pleasure of installing one of these, nor did I recall it only fits MY 1999-2003? I guess people with the older trucks have to deal with the stock oval filter housing... SKU: FA-1759 Manufacturer: Motorcraft Ford number: 2U2Z-9K635-AA Part Type: Air Filter Fits Year(s): 1999-2003 Engine Type: 7.3 Liter Make: Ford Model(s): F250-550,Excursion Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted August 3, 2010 Share Posted August 3, 2010 I have put quite a few of these in. They are the cats ass so to speak. If you are doing one of the early 99 or "98" models with the small turbo you will also have to replace the air duct that goes from the filter housing to the crankcase depression regulator inlet adaptor. I have the part number at work, its kinda tricky to hunt down on the microphish. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted November 8, 2010 Share Posted November 8, 2010 I have put quite a few of these in. They are the cats ass so to speak. If you are doing one of the early 99 or "98" models with the small turbo you will also have to replace the air duct that goes from the filter housing to the crankcase depression regulator inlet adaptor. I have the part number at work, its kinda tricky to hunt down on the microphish.I got one right now. Can you please give me the part number for the part you speak of? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted November 8, 2010 Share Posted November 8, 2010 Try XC3Z-9B959-AA. I also have XC3Z-9B659-AA in my notes but that might be a misprint. If you have an early 99 built before 12/17/98, and still have the original air box opening into the fender, you will also need the clean air hose, P/N XC3Z-9B659-AA, that runs from the air box to the collar above the valve cover. Good Luck! Quote Link to comment Share on other sites More sharing options...
