STROKER_T Posted August 24, 2010 Share Posted August 24, 2010 Got one here that cranks but won't start,fuse 2.22 has been soldered between terminals,got power on both sides,IDM power relay is clicking with key on... Truck came in 2 months/3000 miles ago for crank/no start concern,i replaced blown f 2.22 and truck started every time since,until it died while driving on customer yesterday,now it's back in my bay... As far as EVTM goes it shows that fuse powers the IDM and PCM relays,as well as IPR power...i'm thinkin the solder thing has took out one or both modules,no communication,has anyone seen this,this one's probly gonna be free,but in my defense,i didn't solder it,that ingenius stunt was done at their fleet shop... Thanks for any ideas Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted August 24, 2010 Share Posted August 24, 2010 I would disconnect (in any order) the IDM, glow plug control module (California Emissions) and the alternator and see what happens... Quote Link to comment Share on other sites More sharing options...
STROKER_T Posted August 24, 2010 Author Share Posted August 24, 2010 Kieth,the only component that stops the clicking is the PCM and IDM/PCM relays...a PCM runs about $700 here(yikes!),only got 1 available for plug in test,but it's out of a '99,thinkin that ain't gonna work for a tester,gotta look it up... Quote Link to comment Share on other sites More sharing options...
STROKER_T Posted August 24, 2010 Author Share Posted August 24, 2010 All-righty then...found a pcm out back off an '02 that runs,swapped them puppies out and still got same problem....it's been awhile since i had a good ass-whoopin....might as well get it over with Got everything on that circuit disconnected,clicking at pcm power relay only stops with pcm disconnected...guess it's time to wipe the dust off the BOB...hopefully somebody else reading this has had this fun filled problem Got juror duty this week,on call status....been living here in myrtle beach for 16 years,first time for the juror thing...no bill payin this week for me Quote Link to comment Share on other sites More sharing options...
Aaron Posted August 25, 2010 Share Posted August 25, 2010 How about the PCM power relay itself? I just had one like that, and it turned out the PCM power relay itself was junk. Quote Link to comment Share on other sites More sharing options...
Aaron Posted August 25, 2010 Share Posted August 25, 2010 Took me a fuckin' hour to find the breakout box, too. Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted August 25, 2010 Share Posted August 25, 2010 Check the wiring at the IPR for chafing on the speed nut that holds the field coil to the valve. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted August 30, 2010 Share Posted August 30, 2010 Load test power and grnd circuits at pcm. I have had low voltage at pcm caused by corroded wires or connectors(green death) cause alot of concerns just like this. Quote Link to comment Share on other sites More sharing options...
