mchan68 Posted September 18, 2010 Share Posted September 18, 2010 Just curious, but has anyone else ever had a 6.0L with a failed air management test where the EGRVP pattern looked something like this? Replacing the EGR valve repaired it, but this one didn't look dirty nor did the intake passages look like it was carboned up, which is unsual for an E-Series. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted September 18, 2010 Share Posted September 18, 2010 EGR Valve position sensor failure. I see it from time to time and have several screenshots. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted September 18, 2010 Share Posted September 18, 2010 Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted September 18, 2010 Share Posted September 18, 2010 Mike... press <print screen>, open MSPaint (or anything better you might have on that IDS) and click <paste> and save as "jpeg". The glare makes it hard to see. Don't forget that the PCM isn't just looking at valve response through the sensor - it is also looking for coherent (as in within the expected range) sensor readings. Quote Link to comment Share on other sites More sharing options...
GregKneupper Posted September 20, 2010 Share Posted September 20, 2010 Seen it so many times I cant even come up with a number to give you. Quote Link to comment Share on other sites More sharing options...
