crappy plastic heater tubes
Well it finally happened, I broke my first heater supply tube. used the search engine and found Greg's input on replacing the offending piece.
Quote:
Just in case anyone breaks that heater pipe, here's the replacement procedure:
Remove the upper fan shroud
Remove the fan
Remove the 13mm nut holding the P/S pressure and return hoses
Remove the 3 10mm bolts holding the P/S pump and set it aside
Remove 2 8mm bolts holding two coolant hoses at the top left front of engine
Position the lower coolant hose aside - twist it up into the fan shorud
Disconnect the right side injector harness
Disengage the crank sensor harness from the heater pipe
Break the old heater pipe near crank sensor harness
Remove 10mm nut holding pipe to the intake
Fish the two pieces out
Install:
Insert the pipe, o-ring end first, between crank sensor harness and upper alternator bracket.
Turn back and forth, Rubik's Cube fashion, to thread pipe into position
Reasemble in reverse order.
This assumes that the normal 07T07 recall is in progress, and the air intake, GPCM bracket, etc. are out of the way.
If anyone has improvements on this method, please let me know...
Be careful! This pipe is stupid fragile...
It went rather smoothly, but still more work than I was doing to begin with. This was from over at the injector recall post from way back.
I remember the first time getting my hands dirty on a 6.4L, THAT was exactly what one of my ex-coworkers forewarned me heavily about. Ever since then, I always pay particular attention to those plastic heater tubes any time I'm under the hood of one of these pieces of shit on wheels.
