6.0 fuel injector test harness
I saw a posting some time ago about someone making an injector test harness from a core fuel injector. I have a few harnesses and am looking to make some of these tools. Could you point me in the right direction? Thanks in advance.
Are you talking about making a "noid light?" The injector connector is used to plug into the injector harness and the coil circuits are wired to two small 12V bulbs. When running the injector electrical self test with he tester installed both lights should flash... that is how I made mine and how I use it.
If you have an old injector harness you can cut off one connector with a length of wire, identify the circuits for each coil. You plug that into a suspect injector to make it easier to check the resistance of the spool valve coils... as you would when performing pinpoint tests "P"
SEE THIS TOPIC
