FordMastertech Posted March 21, 2005 Share Posted March 21, 2005 If you get a plugged EBP tube instead of replacing it, which isn't much fun on some trucks you can clean it by using a grease gun. Remove the quick coupler off the grease gun hose and screw the hose into the tube. Give it a few pumps until you feel the resistance in the grease gun drop and then remove it. Clean the grease from the tube with compressed air and some brake cleaner. The small amount of junk that comes out will run through the turbo and exhaust with out any issues. If the tube is rusted it can explode the tube but you should be replacing it at that point. I haven't had to use this on a 6.0 but the sensor thread size is the same. /forums/images/%%GRAEMLIN_URL%%/cheers.gif Quote Link to comment Share on other sites More sharing options...
Dale Lakin Posted March 21, 2005 Share Posted March 21, 2005 I haven't had to use this on a 6.0 but the sensor thread size is the same. /forums/images/%%GRAEMLIN_URL%%/cheers.gif Same sensor as the late 7.3 Quote Link to comment Share on other sites More sharing options...
