joshbuys Posted January 20, 2011 Share Posted January 20, 2011 Did you know that screen filters at 150 microns? And once it's filtered 150, it stops filtering and lets everything in!! Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted May 27, 2011 Share Posted May 27, 2011 I got an old stc fitting and welded a 90 deg fitting onto it with a air hose fitting so I can bolt it to the branch tube and hook up the shop air, listen for leaks hands free and can disconnect it without the fear if an oil spray bath. I knew I read about this trick somewhere on here. Finally got around to making one. Took a 1/4 FIP steel fitting and welded it 45° to an STC. The air chuck can be serviced seperately Quote Link to comment Share on other sites More sharing options...
lmorris Posted May 27, 2011 Share Posted May 27, 2011 Is there a mileage when you guys start to see this failure more often? My 06 has 52k. I have the solid fitting kit ready to go in but I'm worried I might not get to it for a few months I have seen trucks with 200,000 KM that have the factory STC. I figure it's load related. All the one we get in either pull a trailer, have a welder, or fill the box full of stuff. Quote Link to comment Share on other sites More sharing options...
