Sensor Cluster
Mbl35
08 Escape has abs light on b2741-sensor cluster defective. Ws manual dtc chart says to replace the sensor cluster.
Heres what i'm confused about, u1901 accompanies it. At first i figured it's from the defective sensor cluster. The pinpoint test m states other wise, as i go through it, test wants you to check the integrity of the 2 circuits between tyhe cluster and the abs module-thats a bitch to do considering what you got to do to do it.
So i'm wondering if this pinpoint test only appies to u1901 by itself and not accompanied by b2741-or maybe i should go ahead and do the pinpoint test to rule out any other concerns. It's just painful getting that abs module connector off.
Any recomendations?
