1995 f350 oil leak at h.p. pump
working on 1995 f350 7.3 and the gasket between the front cover and the high pressure pump keeps blowing out. verified leak at gasket between pump and cover, replaced gasket using work shop manual procedures, two days later gasket is blown out again. any input as to root cause of gasket failure would be greatly appreciated.the motor is a ford reman with 20,000 miles on it. thanks again
Thanks for the input, due to the cold weather here I was pulled off that truck and asigned other work. Going back to work on it today, I will check gasket part #s to see if I have correct gasket. Thanks again!
