Jim Warman Posted December 27, 2010 Share Posted December 27, 2010 I just came across this from the monkeyhouse.... >I just found my notes from the day I set it up. The Barometric Pressure was 29.825 which converted out to 14.648635072 Psi. (inch mercury [inHg] to Psi. Being that I'm at Sea Level +5' I went with the FF6D setting. I donno where the sensor is for the FIA but it reads the same temp basically as the ambient temperature outdoors same as TFT, ECT & EOT in the morning dead cold before startup. As the engine warms the FIA may rise, i believe. I'm no expert or profess to be one, but just conveying what i've noticed. With the current temps around my area being teens to thirtys the past month or so I haven't noticed my FIA rise significantly. Then again, I really don't monitor it and I've got the Zoodad Mod which is allowing cold outside air to be drawn directly into the intake system and not through the engine compartment where the air temp may be warmer. Hope those Boost Codes work for ya. Post back and let us know for future reference. Best to ya.< OK.. so here is some guy that feels an overwhelming need to compute atmospheric pressure to 9 fucking decimal places. He also knows he is 5 feet ASL (I'm nearly surprised that the number wasn't something like 59.2574689 inches). FWIW, he is responding to someone that wants to know if he can use IAT or EGT to indicate if he has an EGR cooler failure... Man... these guys must be gooooooood!!! Quote Link to comment Share on other sites More sharing options...
deezul Posted December 30, 2010 Share Posted December 30, 2010 Sweet jesus! Quote Link to comment Share on other sites More sharing options...
