stevo90 Posted January 13, 2011 Share Posted January 13, 2011 i have a 06 6.0 van with vgt at 15% at idle and will not build boost till about 50 mph map 14 psi at idle maf at 22 g/s at idle ebp 16 with new sensor and connector after 5min of running the ebp goes to 22 psi never gets over 27 psi on cruise can comand vgt to 35% and the truck will build boost i know i am overlooking somthing simple an help the vgt will come off of 15% after about 35 -40-mph and make boost Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted January 13, 2011 Share Posted January 13, 2011 Are there any DTC's and did you perform the VVT test? Quote Link to comment Share on other sites More sharing options...
stevo90 Posted January 13, 2011 Author Share Posted January 13, 2011 dtc where po299 and they said the turbo had just been cleaned at another dealer to put it outside. ford hotline said turbo is stuck due to ebp pressure the pcm is rolling the vgt back to get ebp down Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted January 13, 2011 Share Posted January 13, 2011 That is why you need to run the YYT test. Do you have the sensor/tool? Quote Link to comment Share on other sites More sharing options...
Dr_Siko Posted January 14, 2011 Share Posted January 14, 2011 Is it possible to install the sensor tool in a van?? Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted January 14, 2011 Share Posted January 14, 2011 I haven't tried it, but it should go without much trouble. If it's too tight, drop the tranny crossmember down (pretty easy), this will give more access on the top of the turbo. Good Luck! Quote Link to comment Share on other sites More sharing options...
Dr_Siko Posted January 14, 2011 Share Posted January 14, 2011 I have an engine to install tommorrow after a 6.0L P.M. 150K miles both coolers, head gaskets, injectors and clean to turbo. I'll test fit the sensor. It will be good to know if it will fit. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted January 14, 2011 Share Posted January 14, 2011 It fits. I am shocked that you guys don't know this after all this time! Quote Link to comment Share on other sites More sharing options...
Dr_Siko Posted January 14, 2011 Share Posted January 14, 2011 Would you believe I have never encountered a stuck VGT on the fleet of ambulances that are serviced here? (We run these units to 350K). I have seen a lot of worn unison ring with a key hole instead of the slot. We also have EGR valves going for more than 100K. Most owners would say we over maintenance but break downs are not acceptable. Too much paper work!! We have a very aggressive P.M. program. Predictable time out of service and contained cost without a lot of surprises. Most owners and many business customers fail understand to power of Preventative Maintenance. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted January 15, 2011 Share Posted January 15, 2011 I understand, I don't want to be in the back of an ambulance broke down on the side of the road. Quote Link to comment Share on other sites More sharing options...
