Allen Posted March 28, 2006 Share Posted March 28, 2006 We have a 2001 4x4 F550 Wrecker with the 7.3 liter motor. The wrecker hydraulics are operated by a belt driven pump off the crank pulley. I need to increase the engine RPM's when we are operating the wrecker hydraulics, but we can not figure out how to do this. Is there a kit or PCM reprogram we can get? Thanks in advance. Allen Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted March 28, 2006 Share Posted March 28, 2006 Allen, you didn't say if the truck came with a pto or if you had one added. If the truck came with one the part# you will need is XC3Z12B641AA If it did not have one the part# is XC3Z12B641BA The manufacturer of the idle up kit is Sturdy you should be able to get them directly or get them from Ford. W/pto 59A-03165 WO/pto 59A-03166 Larry Brudzynski Heavy Truck Specialist Motor City Ford Quote Link to comment Share on other sites More sharing options...
Allen Posted March 28, 2006 Author Share Posted March 28, 2006 The vehicle does not have a PTO, all of the hydraulics are powered off the belt driven pump. Thanks the information Later ~ Allen Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted March 29, 2006 Share Posted March 29, 2006 Read this bulletin: https://www.fleet.ford.com/truckbbas/non-html/apcm_manual.pdf Quote Link to comment Share on other sites More sharing options...
