Steve Mutter Posted February 24, 2011 Share Posted February 24, 2011 Is there an hour meter in the IC. If so how do you get to it to show the hours. Quote Link to comment Share on other sites More sharing options...
lmorris Posted February 25, 2011 Share Posted February 25, 2011 Try the trip/reset button. If that doesn't work try: Key off, hold trip/reset, then turn key to run, cycle through the readings, it may be in there. If both fail then it doesn't have it. Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted February 25, 2011 Author Share Posted February 25, 2011 Thanks I will try it out, Prior approval wanted the hours. They kicked back the form because of it. Quote Link to comment Share on other sites More sharing options...
