64nomore Posted March 3, 2011 Share Posted March 3, 2011 have a 06 e350, had plugged cat, stuck turbo and plugged eqr valve. Replaced cat, cleaned turbo with new unision ring. Now while cruising has a surge, cannot feel it or see rpm change but can hear turbo spooling up and down while driving. Passes all tests, can see ep graph going up and down while surging, any ideas? Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted March 3, 2011 Share Posted March 3, 2011 I assume the VGT command is also cycling? Restricted EBP tube, bad EBP sensor, bad VGT solenoid, sticking vanes, etc. can all cause this. You might want to install the rack position sensor and do the tests to verify the VGT is working properly, or try an EBP and make sure the tube is clear. Make sure the ICP is not surging, too, leading you down the wrong path. Good Luck! Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted March 4, 2011 Share Posted March 4, 2011 When you were cleaning the unison ring did you inspect the control slot for wear? Quote Link to comment Share on other sites More sharing options...
64nomore Posted March 4, 2011 Author Share Posted March 4, 2011 yes, replaced ring per customer request Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted March 4, 2011 Share Posted March 4, 2011 You didn't say what you did with the EGR valve. Quote Link to comment Share on other sites More sharing options...
64nomore Posted March 4, 2011 Author Share Posted March 4, 2011 sorry, replaced egr valve, i pulled ebo tube out and not plugged nor it the fitting Quote Link to comment Share on other sites More sharing options...
64nomore Posted March 4, 2011 Author Share Posted March 4, 2011 Let me try this again, replaced egr valve, today i pulled the ebp tube and it is clean along with the fitting being clean. Sensor also clean. Wish i had a vgt test Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted March 4, 2011 Share Posted March 4, 2011 Wish i had a vgt test That would be valuable right now. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted March 4, 2011 Share Posted March 4, 2011 Wish i had a vgt testOn the flip side, how times have you guys run this test, only to return a PASS result, but still have issues with the unison ring or turbo itself? Quote Link to comment Share on other sites More sharing options...
lmorris Posted March 5, 2011 Share Posted March 5, 2011 Originally Posted By: 64nomore Wish i had a vgt test On the flip side, how times have you guys run this test, only to return a PASS result, but still have issues with the unison ring or turbo itself? You have to really look at the very first 2 and last 2 steps closely. I actually ran the test on one with a new turbo, then compared it to a bad one and you can see the difference. On the topic off the concern at hand, I would typically go after the VGT on this one. I was told that if the surging goes away when taking comand of VGT and EBP settles down the VGT is bad. If it still surges when doing this then go after ICP. Yours sounds very much like a VGT issue. One other thing to look for is if it puffs black at the same cycle as the surge. The last one I had with a bad VGT did this. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted September 30, 2011 Share Posted September 30, 2011 I had one today, 05 F350, customer installed a bullet proof egr cooler and oil cooler setup and ever since it's got a cyclical surge at 15-20 PSI. Since the concern he's cleaned the turbo and replaced the ficm harness You can see the surge in VGT, EBP and EGRDC but nothing in ICP. You can even see it in the boost gauge on the dash. Other than a roadtest with IDS I didn't get a chance to really play with it I don't know if it'll be back or not Quote Link to comment Share on other sites More sharing options...
Mbl35 Posted September 30, 2011 Share Posted September 30, 2011 Maybe the pintle on the vgt solenoid is all crapper up and sticking at times. Quote Link to comment Share on other sites More sharing options...
