OIL COOLER
HAVE A 6.0 HERE THAT I PUT A EGR COOLER IN A MONTH AGO FOR A MASSIVE LEAK. ALSO I REPLACED THE OIL COOLER ASSEMBLY AND
PERFORMED A FLUSH. CHANGED OIL AND VERIFIED ENGINE PERFORMANCE. TRUCK IS BACK TODAY WITH A CHOCOLATE SHAKE IN THE DEGAS BOTTLE. DO I HAVE ANOTHER PROBLEM OR SHOULD I PULL THE PARTS GUY OVER THE COUNTER.
By all means... pull the partsmonger over the counter... not sure what that might fix or even why the parts guy might be at fault....
Could be that the original repair didn't get all the contamination out of the system.... could be the new oil cooler failed for some obscure reason....
Whatever might be the reason for the failure, getting pissed ain't gonna fix squat.
FWIW, the oil cooler is about the only place for the cooling system and engine lube system to swap spit.
Like Mike asks....insert or assembly?
