corygrunt Posted March 11, 2011 Share Posted March 11, 2011 changed both fuel filters today on the truck now it wont run ran fine before and its only got 11000 miles tried every procedure in the manual to bleed the system nothing worked after trying for an hour i pulled the lower fuel filter on the pump housing it was still dry anyone run into this yet Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted March 11, 2011 Share Posted March 11, 2011 Yep. I have done a handful of filters on 2011 trucks. On the second one I had the same problem you are having until I discovered the water drain was open. Quote Link to comment Share on other sites More sharing options...
joshbuys Posted March 11, 2011 Share Posted March 11, 2011 Yep. I have done a handful of filters on 2011 trucks. On the second one I had the same problem you are having until I discovered the water drain was open. DOH!! LOL Quote Link to comment Share on other sites More sharing options...
corygrunt Posted March 11, 2011 Author Share Posted March 11, 2011 ya lol i just got in running i found there was a rubber piece on the end of the drain screw must of fell off while draining it cause for some reason i took the screw all the way out so it didnt seal up put it back on primed it a few times started right up lol dumb mistakes cost you Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted March 11, 2011 Share Posted March 11, 2011 Hey, shit happens. I see this 6.7L HFCM drain becoming a problem. As simple and seemingly well designed, something just isn't right with it. Quote Link to comment Share on other sites More sharing options...
JSHTech Posted March 19, 2011 Share Posted March 19, 2011 Hey, shit happens. I see this 6.7L HFCM drain becoming a problem. As simple and seemingly well designed, something just isn't right with it. That and the plastic drain plug for the oil pan. How many times can that be opened and closed before it a) breaks, or stops sealing? Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted March 19, 2011 Share Posted March 19, 2011 Originally Posted By: Keith Browning Hey, shit happens. I see this 6.7L HFCM drain becoming a problem. As simple and seemingly well designed, something just isn't right with it. That and the plastic drain plug for the oil pan. How many times can that be opened and closed before it a) breaks, or stops sealing? The oil drain plug gas a lot going for in contrast. It is slightly cone shaped, has loose and aggressive threads and is well lubricated. Time will tell. Before I saw one in real life I thought Ford was going to make the drain plug more spigot like similar to a Fumoto valve. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted March 19, 2011 Share Posted March 19, 2011 Quote: The oil drain plug gas a lot going for in contrast. This is where I will have to say that Navistar engineers have a tad more common sense than Ford boys. Let's see.....put a drain plug in an oil pan that has over 3 gallons of oil behind it and aim the plug straight down where gravity can do it's job and the oil can drain into an approved drain receptacle, or......aim it straight out the back of the pan towards the rear differential. Gee that's a tough call. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted March 19, 2011 Share Posted March 19, 2011 Good point. Okay, so it that three things going for it and one against. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted March 19, 2011 Share Posted March 19, 2011 Ah, it could be worse, it could be aimed at the radius arm! Kinda like a '97 Explorer with a 4.0l SOHC. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted March 19, 2011 Share Posted March 19, 2011 Ah, it could be worse, it could be aimed at the radius arm! Kinda like a '97 Explorer with a 4.0l SOHC. Cardboard. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted March 20, 2011 Share Posted March 20, 2011 I'll do you one better, I upgraded my '97 'Ploder to a '99 lower pan that aims the plug down a little more. Then I upgraded the whole motor to a 5.0l. But that has nothing to do with a 6.7 that wont run after fuel filter changes. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted March 20, 2011 Share Posted March 20, 2011 I upgraded my '97 'Ploder to a '99 lower pan that aims the plug down a little more. Then I upgraded the whole motor to a 5.0l. Can you PM me everything needed to do the swap? I have a co-worker with a '97 'Ploder who seems to be hot and horny about doing such a swap to his. Quote Link to comment Share on other sites More sharing options...
