6.7 Demonstrator
Bruce Amacker
Pretty cool....
If you are dealing with wide eyed neophytes, "labs" like that will have them amazed and captured.....
If you are dealing with someone with no small amount of experience... someone that has a grasp on volt drop testing (I figure if you have a handle on proper volt drop tests - you have made it to where you need to be), then Bruces cut-aways are more valuable.
The "lab" says "here is your arm".
The cutaway says "here is you appendix... and it is this far away from your...".
I can walk out into the yard, open a hood and see a 6.7 (no need for a mega-dollar test jig). To see how a cylinder head casting inter-relates with valves, ports, injectors, glow plugs and what-ever..... I need Bruce.
Now I feel like a cheer-leader.... "rick 'em, rack 'em, ruck 'em, ruck 'em... grab that ball and really run....".
