6.0 crank no start
2005 6.0 173 k
hard start no start parameters are all there
1200 icp cranking
65 fuel pressure
no codes
ficm voltages 11.5 and 48
tried know good ficm
has sync and ficm sync
4 new injectors 3 months ago
3 new ones on other side 8 months ago with studs and egr delete
air tested high pressure oil system held great to 500 psi
truck drove to dealer for accessories and now wont start
What accessories were installed? Was it still in the shop when this condition began?
What is your ICP VOLTAGE?
And IPR... enquiring minds want to know...
was in for driving lights and running boards.... my icp voltage is at .8 and my ipr % is 87% then drops down to 23% while cranking as pressure builds and the accessories never did get installed couldnt get truck into shop...... tried the disconnect icp sensor as well....
Man!!! This is like pulling teeth. When is the ICP 0.8? KOEO? Cranking? For IPR to show 87% and then drop to 23% - something don't smell right (KOEO IPR is usually 14% - caution, memory thing). FWIW... IPR is the PCMs response to the ICP reading... Just so we know, what are SYNC, FICM_SYNC and FUEL_PW showing? While cranking....
Ditto on all above, unplug the ICP and see if it starts. ICPV should be .17-.24V KOEO, IPR is 15% KOEO (I think actually 14.85%, Jim), but if the IPR is going to 85% there's something the PCM doesn't like in the HPOP system.
The injectors are enable about .8 but it should build 1.5V ICP cranking. DON'T DEPEND ON ICP PRESSURE, ONLY VOLTAGE during a no start!
Sorry for making things not clear...
KOEO ICP .23 IPR 15%
cranking icp 1.9-2.2 ipr 85% then as pressure builds drops to 32%
injector trim is 8.7
i contribute the spike in the ipr due to the fact i pressure tested the high pressure oil system with nitrogen to 500 psi to test for a leak so there is still some air in the oil rails no hight pressure oil leak detected with the valve covers off and ipr electronically closed
If your ICPV starts at .23v and climbs to 2v cranking, your problem is not likely in the HP oil system.
Plug the homemade "dual light bulb tool" into an injector harness and see if the injectors are getting a pulse command from the FICM during cranking. If you have all of the above things that you state, your problem is in the injectors, compression, or fuel.
:grin:
I'll put in my two cents worth. I think it is injectors based on the fact that there are no codes set. I would run an Injector Buzz test with the home made tool in the above post, plugged into each of the eight injector connectors to compare the brightnesses.
Since the vehicle in question is a 2005, there is no EGR throttle plate to worry about, unless it has one of those aftermarket positive air block-offs stuck closed. But if either were the case, the engine would likely sound like a gasser being cranked over with the spark plugs removed.
Will this truck fire up with a hit of Brake Parts Cleaner?
