Mbl35 Posted April 26, 2011 Share Posted April 26, 2011 While removing the oil filter adapter tubes from the adapter on top of the oil cooler i just found a washer with a small hole in it, looks like some kind of restricter. It was in the left tube driver side. I have never seen this before. Is this some kind of remidy for somthing?? It fits in the tube almost perfectly with one part of it a little distorted. I'm not surprised at anything i find on these units here, also i should mention there was blue bearing grease on the cam sensor and yesterday when i changed the oil there was some metal on the drain plug. It was in last month for a blown out egr cooler, had all injectors replaced but has original oil cooler. Also i found one port on cyl.6 intake gasket melted. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted April 26, 2011 Share Posted April 26, 2011 Man, that oil filter is far enough away from the engine already, I sure as hell wouldn't want anything restricting the flow of oil to and from it. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted April 26, 2011 Share Posted April 26, 2011 Ah! Sounds like a quality repair! Quote Link to comment Share on other sites More sharing options...
joshbuys Posted April 26, 2011 Share Posted April 26, 2011 I've worked on alot of vans and never noticed anything like what you're describing. Quote Link to comment Share on other sites More sharing options...
Mr.Meanwrench Posted April 28, 2011 Share Posted April 28, 2011 I have not seen anything like that either. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted April 29, 2011 Share Posted April 29, 2011 Nope. Not me either. Makes no sense as I can't think of any sane reason for doing so. Diabolical sabotage? Quote Link to comment Share on other sites More sharing options...
Mbl35 Posted May 2, 2011 Author Share Posted May 2, 2011 I did not drive it when it came in because i was scared i would get stuck with it but i drove it today. It has a hollow sounding knock thats coming from the air intake tube area. It was running great until i got it on the highway then it sputtered a bit and then took off fine with a lot of power. Cruising good for about five miles until decelerating to the exit ramp it started to misfire. Check power ballance and cyl.2 dead as dead. Take off from a stop and the engine smoothes out. Drive a few more blocks and at a light and 2 dies again and 4 has a slight mis. This continues on and off all the way back to the shop, then in the shop it runs smooth. Relative compression tested 3 times and all 0. Ficm powers all check out good. Buzz test good. Also had a 27 degree span between temp. sensors. But i could'nt change out the oil cooler, we only have one and it's for emergency units. And so i'm told oil coolers are on national backorder until sometime this month? I changed the engine harness for an intermittant stall-crank no start concern this had for a while, the harness was chaffed really bad in one spot. I think it has some loose injectors-this seems to be an epidemic around here. I have seen whole banks go out like two months after replacing all 8(not me i torque them). Can also be failed injector/s maybe from overtightening or a bad stock? Quote Link to comment Share on other sites More sharing options...
