6.4 wrench light on lack of power.
-Customer is complaining of reduced power message coming on in dash and truck has no power,i can't get it to happen and the only code that i get is a p0234 performed ppt(e)couldn't find anything wrong with map, manifold,restrictions,no issues with cac or connections.
-map pid(volt)0.74 - 14.53psi koeo.
-map sensor correlation test:is good.
map(press)pid 14.53psi.
ebp_a(press)pid14.42psi.
baro(press)pid14.35psi.
-performed harness wiggle test,still cannot duplicate issue for customer.
this has happened to him 3 times.
-Freeze freme data for p0234
flt 42c degrees.
eot 93c degrees.
baro 14.645psi.
rpm 2275.
kph 98.
map 36.975psi
any help or suggestions very much appreciated.
this is a 2010 f250 with a 6.4.
flt 42c degrees.
eot 93c degrees.
baro 14.645psi.
rpm 2275.
kph 98.
map 36.975psi
This is a false code set after the last update recall. Ford engineers are currently working on a fix. Will keep you posted.
At this point all you can do is tell the customer "sorry but you gotta put up with it for now".
yes the customer satisfation program 11b23 was performed a week ago, and i found the ssm 21852 and had explained it to the customer.
thanks for the info guys.
