SSM 21894: P164A reseting.
P164A reseting after performing TSB 11-04-21. When reseting nitrogen oxide tables, you must do it 10 times. If it still resets, roadtest in manual 5 at 55 MPH and perform ten 5 second coast downs with no accell. pedal input. Check MODE 6. Confirm 02 SENSOR ADAPTIVE LEARNING ERROR is in range (0.9-1.20). If not perfrom 5 more coast downs.
  • 4 weeks later...
It's worked for me too. I had one that I put the new nox sensor and updated the pcm, did a re gen and p164a came right back. I did the ten coast downs checked the mode 6 data and it has been good now for over 3 weeks now.
