SLBrook Posted May 26, 2011 Share Posted May 26, 2011 What is the easiest way to test to see which injector on a 2007 6.0L is bad if you dont have a scan tool handy? Quote Link to comment Share on other sites More sharing options...
lmorris Posted May 27, 2011 Share Posted May 27, 2011 If you really had to, you could unplug 1 injector at a time and see if it runs any differant. The ones that don't create a change in idle would be the bad ones. I would still try to get a scan tool, or take it someone that has one to get it scanned, then do the work yourself. Quote Link to comment Share on other sites More sharing options...
Fordracer Posted May 27, 2011 Share Posted May 27, 2011 You can also try using a temp gun and check the temp of the exhaust manifold where it comes out of the exhaust port. Quote Link to comment Share on other sites More sharing options...
lmorris Posted May 27, 2011 Share Posted May 27, 2011 Ya, that too. It's amazing how much simple stuff you forget when you rely on scan tools. Quote Link to comment Share on other sites More sharing options...
SLBrook Posted May 27, 2011 Author Share Posted May 27, 2011 Thanks a lot for the replies. I didn't even think about that at all. Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted May 28, 2011 Share Posted May 28, 2011 While the these tips are quite valid and can help to do a crude diag, if you are working on a modern diesel, you desperately need a decent scan tool.... I'm assuming you have an engine miss.... one that you might be attributing to a bad injector when it may possibly have another cause. Do yourself (and your customer) a favour and make sure you have adequate diagnostic tools at hand. I've been involved with repair the 6.0 since it's introduction and I refuse to try diagnosing any running concerns without our trusty IDSs. Without a scan tool, the best thing I can give you is somewhere between an opinion and an educated guess... http://www.edmontonjournal.com/Slave+Lake+dealership+survives/4847725/story.html Quote Link to comment Share on other sites More sharing options...
