no start/theft lite flashing
Seems like a cut and dry PATS key issue or handshake between PCM-IC?
If you encounter this and can't communicate with any module on the network, unplug the trailer brake control module and retry the network test. If everything is back online the TBCM is at fault and should be swapped out.
