Engine Braking via VGT Command
Yes, I learned of this when the Ford people came through town with a 2011 to all of the dealers and in training. The engine exhaust braking is also mentioned in the sales literature:
The available Power Stroke® 6.7L Turbo Diesel with 6-speed TorqShift® transmission utilizes seemless engine exhaust braking to improve driving confidence and minimize brake wear. While you're driving downhill in Tow/Haul Mode and tapping the brake, the combustion process is restricted to help maintain the desired vehicle speed. This big-rig-inspired feature increases towing confidence without wearing down the transmission or heating up the brakes. So when you need extra control coming down that 8% grade towing 20,000 lbs., this feature on the Power Stroke Diesel gives you that extra driving confidence.
