EGR and Fan Clutch Operation
I have see and varified this with my truck an 06 with vxcf9 flash. its more a matter of the p0405 code and has little to do with weather the valve is in place or not. however you will get the p0405 with no valve.the best i could get out of active commanding my vdf was 1500rpm at 100% fanvar# with rpm 1200.
another tech also found the same thing as well at a different shop right around the same time.
both trucks were the same basic set up. no egr cooler and studed. this was using the stock program
also my truck is a 50 state calibration.
hope this helps
